TT SHO PROJECT
Hey, dunno if any of you remember me... i was the guy who started a tt sho project but failed and did a single 16g turbo instead.... well its been a really long time since iv posted.. ill try to give an update on whats going on now... is the car still running??? Yes and no... the crank sensor died on me, but besides that everythings still a o k. im planing on Adding a 14b turbo to the mix to make a Bi turbo sequencial setup... teh 16g will be the main turbo then when the 16g spools upto boost it will divert the exhuast flow to both turbos and the 14b will spool up adding some much needed air to the aquasion. the way it will work is ill have 2 boost actuated exhuast cut outs... one on the cold side outlet of the 14b to not let the flow from teh 16g go backwards into the 14b... and one befor the hot side of the 14b so it wont spool till its needed... both cut outs will open at the same time when boost is reached.... now befor you flame me for thsi idea and say it wont work... do some reading up and you'll see it Will work and DOES work as others have done this meny times before.. and ill hopefully be getting some 48lbs injectors of the new design when i get some "extra cash" things will take a while for me since i have a kid on the way in march so i really cant be wasteing money on the sho but i will still get er done
... well thats all for now.
-Bob.
-Bob.
