SHOpar
Hey Everyone,
I initially thought I might be able to get away with just replacing the clutch in my SHO and swapping out the Mobil 1 ATF for the GM Syncromesh fluid. Tonight I crawled under the car to change my oil and saw the trans has started leaking worse than it was before. I even checked the fluid, and it's a little low.
It looks like a majority of the leak is coming from where the rod shifter goes into the trans, as everything in that area is soaked, and the shifter and support rod are coated with fluid their entire length. The underside of the car is also wet behind the trans.
Has anyone else had this problem? My trans never leaked a drop until I installed Mobil 1, and all it has done since is get worse and worse. jpshakeh
What are my aftermarket rebuild kit options, since nothing's available from Ford any more? If I'm going to rebuild it, I want to replace as much as I can...
Thanks a lot for any info!
