carterh
1993 MTX with 160,000KM...
I had the car in the shop to investigate an intermittent CEL, noisy passenger front tire, and starter issues. CEL memory turned up codes 542 (fuel pump) and 176 (lean exhaust). They cleaned the MAF. The wheel noise was from the wheel bearing, which was replaced, and the starter drive was also replaced.
When I sent the car in the cruise control worked just fine, but now it will not respond at any speed/rpm. Do you figure the repairs may have had something to do with this, or that it simply died on its own? Where should I start for trouble shooting on this... I have absolutely NO experience with vacuum/cruise....
Cheers!
carter
Cheers!
carter
I guess I should have been more specific and utilized the term "actuate" instead of "use".
