I tried to start my car tonight, and it would crank but wouldnt turn over.
I checked the fuses, and two were blown. I also noticed and slight burning smell. The fuses are the ones under the hood. They are the two smallest fuses in the fuse box. They are nearest to the fender of the driver's side. They are labeled "10"
I was not able to check codes, the codes would not flash.
As dumb as I am, I then jumpered the fuse locations and then successfully started the car, I immediately cut off the car and noticed smoke coming from the area where the over flow bottle is for the radiator coolant. The smoke appears to be coming from wires.
I know that I made a big mistake by jumpering the fuse location. I am also certain that the wires in the radiator bottle location and damaged, these wires are near the passenger side fender.... (I also believe the damaged wires are what caused the fuse to blow initially.)
How would I go about to fix this matter? I need the car to work by saturday cuz I have to drive back to NYC to go to my job. And my folks are out of town, so I dont have a loaner
thanx in advance
thanx in advance
