Markus
NoSho - that's very impressive work. How did you figure out the mods to the EATCs? I assume you have the electrical schematics for them?
NoSlo said:The rewiring was necessary because the 1999 Expedition display board that I used for the conversion has completely different ribbon cable wiring than the Taurus or Continental EATCs. Not a single pin in the ribbon cable is the same, and in fact there are two less wires, because two of the keyboard matrix buttons run over the same wires in the ribbon as the signal wires for the display. I didn't anticipate this when I bought the unit, but I made it work. One nice thing is that whereas bulbs on the 1996-1997 EATCs are still socketed with holes on the display board, the 1999 board had the bulbs soldered directly onto the surface of the board (making it near impossible for the average user to replace bulbs of course, but making it easier for me to solder the LEDs on.)
Markus said:NoSho - that's very impressive work. How did you figure out the mods to the EATCs? I assume you have the electrical schematics for them?
ohioshodude said:.......... now all i need is for someone to reprogram the processor on these things to say SHO instead of OFF and have the outside temp work like it does in newer cars, as in it stays on untill turned off or another button is pushed.
how muchMinnesho said:so who on here can make it say SHO instead of off? I will pay you....
MYSHO1 said:how much![]()
dude that looks so HOTT!!! Very good job. I wish I had that sort of patience.
