1993MTXSHO
Its a Taurus...
As the title states, it's horrible. I have never driven a worse shifting sho in my life. The thing does not go in and out of gear smooth if the car is running or not, clutch in or not. Although it is best with the car off and clutch in but it is still blocky and rough then as well.
I have put the car in 4th gear (while running) and waited 10 seconds and then went to reverse and got no grind; so that tells me the clutch isn't hanging up. The clutch (spec stage 2) and TOB (ceramic from shonut) have about 4k miles on them. However they were from a different tranny and my ******* forgot to replace the quill sleeve when I installed everything on the new tranny. Now I know things like ot wear in together, so maybe everything is ****** off because the parts were used?
The TOB (I think) is making noise with the clutch out, but goes away as one would think when I put the clutch in (wrong size quill sleeve for this bearing possibly?). Could that make me have all sorts of issues like this?
The car has a new clutch cable and I have adjusted the clutch (unless the quad is broken or something is not adjusting right?) The rod shifter is tight and my motor mounts are perfectly centered between the tranny gates, this car should shift as well or better then any sho on the road but there is definitely something not right. The trans was rebuilt 4k miles ago (so the PO said when I bought this tranny years ago) so I doubt it's internal but I am definitely not ruling it out. I can drive the car and it will go into every gear, but it is very hard to get it in and doesn't seem to be biased to any gears, they all suck.
Any guesses as to what this might be are greatly appreciated, the car is pretty much undriveable in this condition.:thankyou:
