My 92s steering problem
1992SHOMTX
Vrrooommm...pssshhhh
Providence, RI
Im thinking of just picking up my 92 from where its at and daily drivering it because gas costs way too much to drive the regal. If the rack did come off of the subframe how would i fix this? Would there be any other explaination of why the steering feels like there is absolutely no way to turn it? I get maybe a 1/4 of a turn each way before i have to force it really hard and it seems like something is rubbing under there.
*Edit* Car's only got 106k
Thanks in Advance
Chris
projectSHO89
SHOless In St L
You'd better get under there and inspect the suspension. It might be the subframe has dropped due to failure of the mounting bolts or bushings.
If the subframe is still attached correctly, it likely needs a new rack.
It is extremely unlikely that the rack has separated from the subframe.
Steve
1992SHOMTX
Providence, RI
ok. I dont have the car here at the moment. If i get it back today ill check it out. Ill add more info later.
SHOTIME
Giver of life
Boston Ma.
Weve got a ton of members in provi and the area who could help you figure this out.
MYSHO1 for starters is in WW and has a TON of SHO knowledge.
1992SHOMTX
Providence, RI
i know who pat is...i bought the 92 off of him...and jays down here too along with brian...and a few others
