My 92 MTX Nos VS HER 93 ATX Super Charged
SuperHO
Mental Patient
St. Joe, MI
Yeah, but that blower kit costs the budget for BOTH cars......theoretically, he could pick up a blower on ebay for $200-400, a blow-off/bypass valve for dirt ass cheap, a FMIC for the same amount of cheap, build his own piping and blower brackets and only be out 800-1000. It's the same thing I would do If I had the time, resources and tools.
BlackonBlack89
burlington county,NJ
u do know vortech and procharger heads units are alot more then 400 bucks. Considering they are 1200-2500 new. Vortech is expensive
Sound like an awesome build. IMO i ditch the atx totally and teach her to drive stick. The atx is a money pit itself
2sho4me
Erik
michigan
The Chip is a SCT red chip From Ford Performance Specialists They tell me that this chip is matched and tuned for the 80mm maf and the set up I will be running and will give me up to 35-50 hp. They have been around for a long time and they tell me the chip they sold me is Great. I see that they are also recomended Highly by this site.
Kens1992mtxSHO
The Commonwealth
I've used mine in more than one SHO also, however it is not possible to use them in more than one car at a time. (probably what he means)
2sho4me
Erik
michigan
I guess I will just put the chip in and then dyno the car and see where it is at. Then go from there.
1995SHO9
FLEES ARE COMIN
Carlisle PA
This is going to be a 6 Month MICHIGAN SHO Down! Lets see who comes out on top me or my Wife! We Both will be looking for YOUR input and ideas to help use the money to get the best out come.
Here are THE RULES we both had to find a the best SHO 2 Gen we could for only with each having $2,000 to Spend & Only $2,000 each to do upgrades Parts Only Labor with be done by Me and Her Dad! My Wife will be going for a Vortech S trim 9 PSI looking to Get 380hp. Myself I will be Going for 100 Shot NOS and other mods to get 380hp.
My wife struck First with finding Her A Nice Red 93 ATX 3.2 with 103,000 for $1420 from Wisconsin she talked the guy down form $2500 Great Job! That Gives Her $2560 to Spend on Mods and upgrades.
Her Car came with
100% Stock 3.2 Motor
New Performence Tires
Dynomax Exhaust
Rebuilt Trans
Upgraded Brakes and Cross Drilled Rotors
I waited 2 extra weeks and found a Nice Green 92 MTX 3.0 with 67,000 Original Miles From 50 year old man from Maryland for $2,000 ( I think I did a little better) That leaves me with $2,000 for my mods & upgrades
My car came with
100% stock 3.0 motor and clutch
Sho Shop Brake Kit
complete Dynomax Exhaust Kit y pipe cat back,
Tokico Shocks, Struts
Eibach Springs
Sho Shop sway bars
80mm MAF
Cold Air Kit and
Sho Shop Smaller Performence pulleys.
Alum Bushings
I will update weekly the Mods we each buy for each of our SHO's
Hit me up if you want. I might come down and help you put on the blower if you are interested.
2sho4me
Erik
michigan
Does it matter what kind of Turbo I buy? All the tubes have to be custon made anyways? Can I use a t4 turbo?
1995SHO9
FLEES ARE COMIN
Carlisle PA
Yah the turbo matters. If you put a small one on you will pretty much have instant boost but will most likely run out on the top end. If you use a huge one like I have, the boost will come on later but it will hit violently and hold to the redline. A medium one would be nice all around. All the tubes do have to be custom bent. and you can use any turbo you wish, how they perform will be differnet though.
TYSHO
Earth
Sounds like you're good if you port the intake, install a larger fuel pump, BBB's, and performance clutch. You'll have at least another $1000 to play with for tuning, spark plugs and wires.
You'll need to reinforce your front and rear motor mounts, also. You can do this with a drill and $15 for supplies.
nik97
Mile high
Having had a ZEX dry 100 shot and an intercooled turbo setup on my car, I would say go with a turbo. It can be done relatively inexpensively but takes time and research. As far as the basics go, a t3/t4 would suite you well with a medium sized intercooler. It's just a matter of how you want to route your setup.
SuperHO
Mental Patient
St. Joe, MI
?? When did this happen? I have swapped my tweecer between a number of cars.
My bad...I think I was thinking about the XCal tuners...
If you're getting 30-50hp from that chip, then I got gypped, cuz I have the same one custom tuned by Doug Lewis himself from FPS. Realistically, you MIGHT see 5-7whp from that chip....and even then, it'd be better to find someone who can tune a superchip with the car on the dyno. I'm not doubting Doug's ability to tune, but it's hard to make the tune perfect for the engine, since each engine's different, without realtime data analysis.
I still vote for the twEECer. Sell the chips and put the money elsewhere. IIRC, he only charges $50 to reflash em.
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
john you relise hes in michigan that would be a **** of a drive to help out..
also the turbo pipes your talking about do you mean exhaust or intake? cuz they make intake pipes thats universal and you just piece it together for the bends..
also for both you guys in your goals to make a faster car... take $60 and do the rod bearings... its a wise choice to not blow the engine trying to race...
93rev2sev
Hockeytown
For once....
I agree with Brian. Although...since it's YOUR project...don't take it to him.
Brad kirk
