Multiple ABS codes pulled!
ShoMe1More
FL
I originally thought I only had one code (ABS 22), but I took it in to my local mechanic and he pulled these: 22 23 24 25 28 31 33 43 44
Any sense of whether this is a combination of sensor problems and circuit problems. Or do all those codes add up to the ABS Control Module being bad?
kevinspann
Don't take my advice.
Richmond VA
I had a bunch of codes and an intermittent light - and the codes weren't always the same. Per the manual I did all of the tests to check the wiring and the sensors, and it all seemed to check out okay - then I decided to swap in another control module and haven't seen the light on since.
Not sure if it's your issue, but it certainly could be. There are also two ABS relays that can get corroded, they plug in down under the controller.
Or if you want to try another controller, I have one from a '90 that as far as I know, is still good.
