The abs light on my car started coming on when I first start the car and staying on. If it doesn't come on when I first start the car it stays off the whole ride.
I just ran the codes and got a code 22, 31, 33, 35, 37, 43, 63, and 75.
22-LH front inlet valve
31-LH front sensor
33-RH rear sensor
35-LH front sensor
37-RH rear sensor
43-RH rear sensor
63-Pump motor speed sensor
75-LH front sensor
In the past with other cars i've had issues with wheel speed sensors and abs valve body going bad. Thankfully because of the forum I was able to find the test procedure to do a resistance test on the valve assembly and I found an open.
I'm guessing in this situation I should replace the computer and check my battery and charging system. I read in another thread someone had issues because of battery or charging issues.
31-LH front sensor
33-RH rear sensor
35-LH front sensor
37-RH rear sensor
43-RH rear sensor
75-LH front sensor
