blacklabel
I tried searching and I found out some fluids to use, but I am unsure what blocking rings my transmission has and if it matters. My brother said they were made with a different material for the blocking rings and I just wanted to double check what fluid I should use. I think my car might have brass blocking rings as it was made in 4/91 and it has a cable shifter. Does it matter which type of blocking rings the tranny has? My brother recommended Mobil 1 ATF and I just wanted to double check to see if that would be fine in my car. I would rather make sure it is fine now instead of learning after I would put the stuff in.
Thanks.
Thanks.
