MTX Transmission fluid
blacklabel
Hartford, WI
I tried searching and I found out some fluids to use, but I am unsure what blocking rings my transmission has and if it matters. My brother said they were made with a different material for the blocking rings and I just wanted to double check what fluid I should use. I think my car might have brass blocking rings as it was made in 4/91 and it has a cable shifter. Does it matter which type of blocking rings the tranny has? My brother recommended Mobil 1 ATF and I just wanted to double check to see if that would be fine in my car. I would rather make sure it is fine now instead of learning after I would put the stuff in.:)
Thanks.
Mika
Bedford, Tx
I have a '92 and that's what I use, Mobil 1 ATF. I've been happy with it.
Mika
Shoaz
Studly dood
Scottsdale, AZ
Mobil 1 ATF is an excellent choice and should work regardless of which blocking rings you have.
Also, there's a simple mod to install a drain plug at the bottom of the tranny. If there's not one already there I'd recommend adding one, as it's the easiest way to get the old fluid out. Instructions here.
shovermont
unleasing my 91
Vermont
hey about that relocation. is it worth doing all that? my sho is still sitting and i think checking it first and im sure its probably old and not in runable condition. can anyone explain how to at least check it? thanks
