MTX tranny flush?
masho95
got Zex?
Chicopee, MA
SHOstuff said:
Well that's funny cause when I opened it all the fluid came out and drained. And then I replaced it with fresh fluid. You have to know what you're looking at and it's either 1/2" or 3/4" drive, I get them mixed up, but you use that to take it out. I know I'm not mistaken.
Actually you are mistaken... the "bolt" that comes out with the end of a 3/4" drive IS the fill plug, and the only reason fluid will come out, if the car is completely level, is if the tranny was overfilled with fluid. When properly filled the fluid level should be even with the bottom of the fill plug hole, not pouring out of it.
masho95
got Zex?
Chicopee, MA
NotSoSlowSHO said:
No, just quit dumping fluid into it when it starts to come out of the fill hole :beer:
Yup, and when it stops dripping the fluid should be level with the bottom of the fill plug hole and at the correct level. A COMPLETELY empty tranny (case halves removed and ALL fluid out) will hold just under 3 qts of fluid. LOL the factory car manual says that the tranny holds something like 5.5 qts, so don't go by that or you're going to have 2.5 qts of fluid on the ground. :)
Denny
Taurus Homeland
Atlanta, GA
Like Jesus Christ, back from the dead
Bizzy said:
1 - The shift interlock bolt commonly used for a "drain plug"
2 - The fill plug. This particular one doubled as a spider nest. :)
Or as you would see it from under the car.....
The bolt in pic one goes through the case and sits in the groove of the shift interlock in the area noted in the pic below.
Any chance these pics could be updated? I'd like to check my tranny fluid level before I drive the SHO again since my tranny seems kinda stiff :confused:
shobroooo
