JATO
This isn't quite an SHO problem but the source of my issue I believe is in the speedometer drive in my MTX-4 transmission. The car is my '06 Vulcan with the MTX conversion. The issue is a bouncing speedometer needle when holding a steady speed. With cruise control set, the cruise tries to counter the bouncing needle and causes the car to surge. The speedometer is electronic and is driven with the SHO VSS. I swapped out the speed sensor and the speedometer is still bouncing. Has anyone had issues with the actual speedometer drive and gear in the transmission causing "slop" in their speedometer? The only two possibilities are the drive in the trans or the speedometer it's self.
