MTX Rebuild Kits
artsho
New York
Check this out has anyone ever heard of them :salute: These quality manual transmission parts and rebuild parts kits are designed to be top of the line overhaul kits. http://www.drivetrain.com/transmanualrebuildkit.html#FORD CARS We have include information on how to identify individual transmissions, application information, model year,and detailed kit and part availablity by transmission type. The Ford transmission that is covered in this section is the RWB (FWD). Typically used in ******., LN7, Lynx, Sable, Taurus, Tempo and Topaz's requiring 5 speed applications.
Different overhaul kits are available depending on the extent of the overhaul that you plan, the contents of the kits are described as follows:
· Paper Kit: Gaskets & Seals. If there are no gaskets for a particular transmission, no kit will be available
· Bearing Kit (FWD): Main bearings and seals only. No differential carrier bearings or nuts.
· MRK (FWD): Main case bearings, differential carrier bearings, nuts and small parts as they are available
MRK100245 Master Rebuild Kit SHO1989-95 $212.82
SK245 Synchro Ring Kit SHO - Lined 1st - 4th 1989-95 $123.83
301686 2Differential Carrier Bearing SHO 1989-95 $18.90
$ 355.55
