My water pump idler pulley bearing is screaming, so I guess its days are numbered.
Anybody know where I can get a new one?
The measurements are 20mm center, 37mm outside diameter and 15mm thickness.
I have found 20mm center, 47mm outside diameter and 14mm thickness.
If worse comes to worse, I could always make a custom aluminum pulley and use on of these bearings, but it would be easier to find the original.
Jose
Jose
