MTX flluid problem
zach44102
BIG TURBO
Georgia
So my mtx leaks, not a huge leak but every time I get under the car I can see it weeping out between the case halves. And When I work on the car in the car port for a couple days it will leave a spot. My MTX's fill plug is not coming out. Trust me its not, its been rounded out. I have been adding a quart of ATF every month or so but my question is, Whats the worst that could happen if its over filled? I know running low on fluid could be explosive to the trans.
Edjukate me.
kevinspann
Don't take my advice.
Richmond VA
I don't see where over filling it would **** anything. Maybe add more drag inside of the transmission from the fluid. I think there is a vent it would come out of if it were too full (maybe I'm wrong).
whiteman_01
Well-Known Member
Hastings, MN
I didnt think you could over fill it. To the fill hole is full, anything else just comes out of it.
JRA2000TL
The Complainer
Daphne, AL
Yes, you can't really overfill it. Know how I know this? When I changed mine in the 89, apparently I thought I took out more than I did. When I proceeded to funnel in a nice 3 qts and pulled the hose from underneath, I received a nice bath in trans fluid. It will leak out until it gets to the fill hole.
crazy_canadian
Rattle-Mobile
Quebec
He said his fill plug won't come out, so I assume he is filling it up by the reverse switch?
I don't exactly recall at what exact height the plug is, but look the difference between the plug and the axles.
If I remember correctly, oil should come out when you pop an axle, but no more than 1/2 a quart. (again, IIRC) You could look at it, and pop on axle out to give you an idea of how much oil you have in your trans.
Edit :
And the fill plug is made of steel. You could also weld on a bolt, then screw it off, and put a new plug in.
91PDXmocha
Portland , Oregon
If its leaking between the case halves at some point you need to remove it, split the cases and re-seal with Permatex 51031 aerobic sealant. but do what you will til you can get around to fixing it the right way.
zach44102
BIG TURBO
Georgia
Edit :
This is more the situation. If I dont have the fill hole plug out and I over fill the trans whats the worse that can happen? Blow out axle seals? Removing a axle just to check the fluid level sounds like a waste of time and a big pain in the ass.
the worst thing that can happen w/ too much oil is to blow out the input shaft seal and ruin the clutch.
I think what you are doing is the reasonable thing to do until you can pull the trans and re-seal it and fix the fill plug. Try shining a flashlight down in the top hole to see if you can see the fluid level.
