FORDGUY1022
I will be needing a rebuild on my transmission soon and was curious if anyone has looked in changing to the mtx 75 what are your thoughts
Also, it doesn't bolt up at all.
What kind of power are you puttin to the ground
There is a mazda gearbox that'll bolt to a sho engine as well, I think its the H-type IIRC. You'd actually need two different ones to make it work though. The bell housing side of the case from a 3L Vulcan out of the first gen probe gt, and then also the case and internals from a F2T powered probe gt or mx6 gt......gearing might be weird, but my friends f2t mx6 is putting over 500 ft lbs through his stock h-type. I believe there are less expensive differentials for those as well.
No i dont know him
