Mtx 75 transaxle
FORDGUY1022
Texas
I will be needing a rebuild on my transmission soon and was curious if anyone has looked in changing to the mtx 75 what are your thoughts
dohcsable
Gold Calipers>*
Indiana
Also, it doesn't bolt up at all.
Doesn't even come close at all.......sad because the spline count for its axles is the same. I tried to fit a focus torsen in an mtxIV......it wouldn't. A $500 diff sure would have been nice.
shomethe$$$
Washington D.C.
I considered the MTX75 gears, at first I was impressed since they offered the straight cut set as well but overall the gears and syncro's weren't good enough.
shomethe$$$
Washington D.C.
The perhaps canfield can make an adapter for you or use the 3.0L canfield, weld up the 5.0L holes.
shomethe$$$
Washington D.C.
I can't remember where they said the break started. But it looks like it was the pinion and it spread from there.
dohcsable
Gold Calipers>*
Indiana
There is a mazda gearbox that'll bolt to a sho engine as well, I think its the H-type IIRC. You'd actually need two different ones to make it work though. The bell housing side of the case from a 3L Vulcan out of the first gen probe gt, and then also the case and internals from a F2T powered probe gt or mx6 gt......gearing might be weird, but my friends f2t mx6 is putting over 500 ft lbs through his stock h-type. I believe there are less expensive differentials for those as well.
The mtx75 differential appeared(I didn't have anything to measure) to be a different diameter where the ring gear bolted up.
probe_racer
california
The transmission from a vulcan powered first gen probe LX will bolt up to the SHO with minimal modification ( a little bit of grinding to clear rear oil seal thingie) the ratios on the transmission on the LX and GT probes are a little bit different but internally everything is as strong and interchangeable.
dohcsable
Gold Calipers>*
Indiana
I had never even considered that trans until seeing it hold an f2t. PR, I assume you probably know the guy that goes by celicahalftrac on the probe/mx6 boards.
