motor will not idle
rocket455
Fairfield, Ca
so i just built this motor and dropped it in. it starts up but will not stay at idle. the motor will not stay alive unless i give it gas. and it does not sound like a clean smooth running motor unless it take it up to around 4k rpm. and when you would think "ok that hiccup is gone, i can let the R's back down and it should stay alive"......nope. dies. now i have the shonut fuel pressure regulator on here. if thats not set right would that be the culprit? any input is welcome and i thank you ahead of time for it. :salute:
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Check and make sure that the spark plugs are hooked up correctly. Some of the manuals are not correct. Grounding strap hooked up?
SuperHO
Mental Patient
St. Joe, MI
The strap goes from the rear head by the diagnostic port to the firewall by the hood strut. Can't miss it if it's there.
You can check fuel pressure via the Schrader valve popping up in the middle of the intake runners. Should be running around 50psi at idle.
And correct me if I'm wrong, but is plug #5 and #4 bass-ackwards on the coil pack in the diagram? Shouldn't 5 be on the bottom left instead of 4?
rocket455
Fairfield, Ca
ok i found the ground strap. it was not connected. but it doesnt make too much sense to me. it goes from the firewall to the intake on my friends car.....why would you be grounding the ALUMINUM intake?
SuperHO
Mental Patient
St. Joe, MI
You mean aluminum doesn't conduct electricity? Tell that to a ladder company...
LOUDSHO92
Sponsoring Vendor
Was the idle screw screwed with? Do you have an LPM?
You might want to reset the idle too and that might help. Since the computer has been drained probably you can reset it and might bring it back to normal.
rocket455
Fairfield, Ca
well, now i had just installed the stock fuel regulator. ill put in the shonut unit when i get closer to my setup. now it starts up and idles at 1500 and i give it a little rev and it settles down to about 800-900. and yes i have an lpm. since its been so long would i have to reprogram it for my cams and other mods?
LOUDSHO92
Sponsoring Vendor
I would first reset the idle. I believe SHOtimes has a how too. Your computer needs to relearn the idle. I would probably do it without the LPM. Once you put the LPM in it should take care of the mods.
rocket455
Fairfield, Ca
ok everything is going smooooth. then suddenly, the motor starts to studder and drop r's down to about 500 and shake, then you can hear the air intake cut out then the motor dies suddenly after.....what gives?
Sounds like the IAC can't keep up.
Try whacking it with a screwdriver handle when it's stumbling and see if the idle improves.
Aleffewmo
SHOYoungin'
Kalamazoo, Michigan
x2
Same thing was happening to me, and JoesSHO wacked my IAC with a screwdriver handle a couple of times and it started and ran fine.
