Red Baron
Flyin' High
I installed my y-pipe yesterday and when I went out for a test drive, I heard an exhaust leak...I looked it over and the bolt where the donut gasket is wasn't tight because it was too long....
Soooo, I took it to the exhaust shop, they cut the bolt a bit, now the connection is good and tight. But, there's still a leak.
They put the car in gear, stepped on the brake and gave it a little gas...the motor tilted forward big time...put it in reverse and the same thing. The guy says that when I gas it, the engine movement is causing the ****** to move and causes the leak. I saw it move when he did the test.
Also, when I'm driving and I gas it hard, especially in first, I see the shifter move forward and down.
When I was installing the y-pipe, I saw that the rubber on the front motor mount (the mount on the passenger side on the front side of the engine) was pretty cracked. I'd post a picture, but I seem to be having problems with uploading them to cardomain.
Can bad motor mounts cause the leak because of the movement? Does this mean I need new mounts? There's two? How much work is it to put them in? Thanks for any info.
