Motor Mounts
lifesave
1989 (RESTO), 1994 atx MINT
florida
Ford just told me that my motor mounts are bad, and it ripped out my power steering hose because the engine is torqueing too much........ Really!
How hard is it to change motor mounts on a 94 ATX???
pretty easy. normally, just the front one goes bad, but check both.
lifesave
florida
Okay I might give it a shot myself< will check with advance for parts first!
Thank you!
typhoon5000
Ferd Enganear
Shelby, MI
The big buck parts stores only offer the rear mount. You either gotta get ones from SHO Nut (if they have any left) or scrounge the junkyards. Good luck!
lifesave
florida
Good News! Advance stores do carry all 3 mounts $137.00 for all three mounts! they carry the solid and semi solid mounts. you have to tell them to push the green button on there screen to open up all that is available!
Now best way to install them?????
put a piece of 2x6 on top of your floor jack and put it under the oil pan and lift the engine just enough to get the big bolt to disengage from the subframe.
lifesave
florida
okay great, going to give it a shot this weekend,
Here is the part #s from advance and pricing
tranny mount # 2717 $25.99
motor mount #2968 $51.99
motor mount # 2967SR $49.99
All have limited lifetime warranties
they look right in the pics, and Advance Auto says they are the right ones, so you should be good.
SHO Continental
Moderator
Northridge, Cali
Cross your fingers. I bought some Anchor mounts for my gen4 and the stud broke on one during install before it was even close to proper torque spec. Made in China, yaaaaay.
Dsc04376
