Motor Mounts Again?
SHO_ROLLER
Florida
Well, this is going to be a little tough to explain, but here it goes. If I'm going down the road (60mph) and let of the gas abruptly, I'll feel a little movement back and forth, if I get back on the gas, same thing. No down shifting is involed when this happens, I stay in fifth. Is this just an SHO thing? I just had the motor mounts done! ANY help would be much appreciated. Thanks!
Anthony :confused:
No, that's not a "SHO thing." It is also not a motor mount thing. You need to inspect your subframe bushings and suspension components for damage or wear. Something is not right. How are your tires?
SHO_ROLLER
Florida
Well, the tires have flat spots because of a bad alignment. The subframe bushings were inspected about a month ago and they said they weren't that bad. I could use some struts for the front, but thats the only suspension component I can think of that might be worn out. What else should I check? Thanks Patt
Anthony :confused:
