Motor Mounts?
dshultz07
Washington
So........
Again.......
Back to my, " ORGIONALY " thread post on SHO noise.
One guy said he had " similar " circumstances , however noting loose couldn't find / locate
Then.......
Under futher inspection by me under hood, when motor moves on " shift " mode from inside the car could it be possibly motor mounts making noise ?
The " formally" know as rubbing/ squeaking/ Styrofoam ect.
J~
Yirmiyahu
Is it when you stopped and you turn the wheel a little either way and makes a creaking sound? Because that is a strut mount.
Just thought I'd ask. I know you said it sounds like Styrofoam squeaking. If you don't think it's suspension, and you're saying it rides rough, I wonder if you got one that already has h&r springs in it.
But for the sound your trying to diagnose, I'm trying to recall if my motor or trans mount squeaked before I replaced them. But I think I could just feel engine movement, and feel a kind of clunk as the trans mount would move around where the isolator bushing was torn when shifting gears. For some reason particularly noticable at slow speed.
Anyway, best of luck. Curious about what you find
Yirmiyahu
Also, if that car has a good amount of miles on, I'd assume motor mounts. I replaced my torque mounts with AD's last year. Recently I replaced both the trans mount, which I filled with poly urethane, and what a substantial difference it made, then, for good measure, replaced the motor mount, which was worse than I though and absolutely needed replacing. I don't know if any mounts had been replaced in the past, before I had the car, I'd been assuming they hadn't. But at my mileage, and if course how is been driving it, they were done. Make sure you use factory mounts, dont get any aftermarket ones, except the AD torque mounts. IMHO
shootinirons
