motor mount question...again
professorkaos93
rules the world
cinci.
so it appears that there is a strut that goes with the front motor mount. the front motor mount on my car looks fine, but the engine will rise if we put it in gear and rev it up letting the clutch out. could the strut be bad and that is what is messed up and lettin the engine come up like that, maybe?
CerberuS
300 HP N/A SHO
Granby, QC, Canada
the engine always moves a little , but when its more then a little , check for:
-Loosed rear Subframe bolts (or failed-stripped-missing:oogle: )
-engine mounts
Dont bother with that little shock, it aint doing crap.(or mostly)
ycode90
Out in front!
-engine mounts
What he said.
professorkaos93
rules the world
cinci.
ok, thanks for the information. i'll try to get under it tomorrow sometime and figure it out. where are the subframes connected at?
Four large bolts, one at each corner of the subframe. Can't miss them.
CerberuS
300 HP N/A SHO
Granby, QC, Canada
Yes , the big ones that holds the whole motor-trans Frame unit. Under the car , about where your feet are at when you drive (thats the rear left bolt)
