Well i think im finaly starting to narrow the problems of the car down. Originaly, I thought that i had a bad fuel pump, but i talked to the owner before me and he had a new one replaced about a year ago. here are the symptoms,the car will not start and the fuel pump is not making any noise.Now i went to check codes however got none. Now when you take codes you put the pin in the signal return and run it to selt test input. Did that, no codes and the cooling fan didnt turn on which i belive it should. Now i replaced the radiator and fuel filter a couple of days ago and thats when the problem started.I hit the inertia switch to do the filter and the car started up but boggy.It was also getting very hot which leads me to belive the radiator wasnt working.Triggered the switch again to make sure it was working then the sho wouldnt start again.Now it just cranks but its not getting any gas.Now, Im pretty sure that the Intergrated Relay Module is in charge of cooling fan, radiator,fuel pump is it not?Is it possiable for that to have bit it and how would i be able to check.Any ideas would be greatly appreciated.Thanks!!!!!!!!!
joe
oh yeah the car is an 89 in case that helps
joe
