More problems...
Tyler
New Mexico
So i'm getting ready to buy an exhaust system for the SHO and today I noticed a new noise. While sitting in park if you turn the wheel all the to left or right when the driver side wheel starts to reach its maximum turn radius it starts to click rather badly and you can feel it alittle in the floor of he car. I'm thinking the problem is with the transaxle but im not sure, please help.
deercrusher
never running!
PA
like the above poster said, check your cv joints. Get under the car and look at the inner and outer rubber boots on each axle and check for tears and leaks. If that's not the problem - check your subframe bushings. Have someone watch the motor while you turn the wheel left and right and see if it shifts to either side while you turn the wheel. It should not move - if it does then you should replace your subframe bushings.
Tyler
New Mexico
will do, thanks guys i'll keep this updated so you guys can help. happy holidays!
