Moonroof module cover
rltrbill
Can anybody tell me how to get the cover off the moonroof control center in order to change the bulbs? It does not want to move forward or backward. This is a 1994 MTX.
Thanks
Epi
Remove the lenses over each small light, the entire piece that you would push to turn the light on. Use asmall screwdriver in the slot between the lenses and they should pop right off. If you ever (and you will) need to change the switch you follow the same steps ,but once in there you will see a screw on each side under the bulbs. Those screws will allow you to remove the entire console without fighting and breaking it.
