Monster Tach Wire Hookup..?
Nick DOll
Independence Mo.
I have a monster Tach and need to know how to instal it...? Anyone done this? I HaVe the directions and it tells me to hook it to a coil...which coil though??? aND WHERE ARE THE WIRES EASILY ACCESABLE, as in power, lighs and so forth. if anyone has detailed instructions please post THANKS! ITS A AutoGage By. Auto Meter.
projectSHO89
SHOless In St L
Nick,
It sounds like the kit is assuming a conventional ignition system hookup.
You should be able to use the TACH signal from the DIS module as your source of this at some point in the dash (on the way to the tachometer in the instrument cluster).
Sounds like you need an EVTM (Electrical/Vacuum Troubleshooting Manual).
Steve
89
