whiteguy3
Scott MacIntire
My built trans in my 94 is giving me problems. This is the same trans that was in Alex's turbo SHO. I have had it of probably 8k now and have had nothing but smiles on face with it...Until now. Car has 3.98 gears, tri-flows, solid mounts, tweecer, etc...
Was driving normally the other day and it downshifted randomly. It now shifts at 3k in each gear no matter what. O/D does work, every gear works. When it downshifts/upshifts it does it hard but does not slip. I have replaced the PCM, cleaned ports and tweecer module, TSS, VSS (might try another), the wiring from the engine harness to VSS, checked pan with nothing out of the ordinary, filter was fine and fluid level was good!!???
This trans has never seen over 190 degrees and has always hit it's shifts great. This is feeling like either a selonoid issue or electronic/sensor issue not internal. For it to do this out of the blue is weird.
I am stumped. Need some help from the forum???
