Missing coolant mystery?
Catastrophe
Lurking in the shadows...
Ok... For the past few days I have had my "Low Coolant" light come on. Every time I check the reservoir, it's emptyand I fill it to proper level AGAIN... The radiator is always full "Right to the top". There are no puddles where I park, although I did notice green coolant leaking down from the right side of the front fender "Towards the outside of the engine bay" a couple days ago... I saw it dripping down, as I was walking towards the car. The radiator doesn't appear to be leaking either...
I think either my reservoir is cracked/leaking or maybe a hose to it came loose...
Do I need to take out the battery to get the reservoir out for close inspection? :shrug:
Camarok
Awesome SHO Member!!
Milwaukee, Wisconsin
Does it smell green?! :evil_gri: Could be that coolant is leaking from somewhere burning off onto something really hot or manifold?! evaporating mysterously!?
Are you "exhausting" white smoke :eek:
Otherwise i really don't know
Catastrophe
It was definitely "GREEN"... That's the first thing I noticed, because the sun was shining right on the small puddle. It seemed to just drip off the right side of the front fender ( Just ahead of the passenger side tire, and equal to where the reservoir area would be right above it ) :confused:
* Also--> No white smoke whatsoever from exhaust or engine............
N3FOL
Pennsylvania
Coolant Mystery
Check the condition of your lower radiator hose especially the clamps. Make sure everything is nice and tight. Good Luck.
projectSHO89
SHOless In St L
A pressure tester from AustoZone's Loan-a-tool program will help you find the source of the leak very quickly.
About a $90 refundable deposit.
Steve
Dual Plenum92
Walkerton, IN
check the bottom of the reservior around the bubble of plastic. i have had the same problem and i found a little crack after taking out the reservior and examining it more closely.
DP92
morpho18
Des Moines, Iowa
i've just recently been having the exact same problem. Last Saturday I flushed the coolant from the car and replaced it with all new. I made sure to look everywhere for leaks, and just couldn't find any. If there is a puddle under my car, its very small, and under the right front side of the car. Definitely not a big enough puddle for the amount of coolant being lost. Is there anything on the front end of the motor that can't be seen with the ***** eye that is leaking? maybe getting trapped in the timing belt covers? I'm really in a pinch here. I've been trying for the past 4 months to get my SHO problem free to make it a reliable daily driver, but with summer approaching, a low coolant mystery isn't very comforting.
NoFlipping
Burbs of Detroit
I just went thru this same thing. Turned out to be a water pump with the slowest leak I've ever seen. Couldn't really tell it was leaking except for the reserve tank needing to be refilled every few months. I took a close look undern the hood - no leaks - until I pulled the splash guard away far enough to see behind the damper pulley. I showed just the slightest residue of a dried coolant drip.
The pump was working fine - no noise/ no temp issues. I think it was just one of the 0-rings degrading (it was all still factory equipment). After nine years, I guess it was just time for rubber failure. I just had to do the valve covers/plugs and the oil pan, as well. So I figured, "I just did the top, why should the front be any different?" So that got done last week as well - pump, CPS, belt, cam and front oil seals.
I think that often it's hardest to see the early vs. the later stages of failure in the rubber parts like these. I, at least, tend to react to/look for the catastophic failures. I think I just got lucky finding this one.
