Mike Kopstain
Hey guys... The car seems to have a rough idle after it's warmed up. The Plugs and wires are new, the IAC is clean and so is the throttle body. No codes. Any ideas?
want to post the PN's for the intake gaskets?sdpatt:
The Motorcraft WR-4033 wires fit both the 3.0L and the 3.2L and can be had from FordPartsNetwork.com for $83.99 and the gaskets can also be had cheaper. The valve cover and plug well seals are $71.99 from AutoZone.com and the two intake to head gaskets are only $12.49 each from the same source.
What plugs and wires did you install? It does sound like the closed loop mode is allowing a faulty sensor to confuse the EEC.
Intake manifold gasket (2 req)SHO91MTX:
