misfire what bosch + 4 plugs
tavius
arizona
misfire with bosch + 4 plugs
I just did a tune up and cleaned the intake im my 97 sho and the car misses when i am driving, before i changed out the plugs the car didn't misfire. how do i verfiy if its my plugs or coil thats causing the problem?
SASHO91
Zoom Zoom
San Antonio,TX
i wouldnt have used the bosch 4's.. for they are not the best plug for the sho....
go get some motorcraft double platnium... :thumb:
also, was the intake dry?
tavius
arizona
yeah the intake was dry.
They don't make the Double Plats anymore and the V8 doesn't need them anyway. The COP ignition has no waste spark cycle.
Get the new Fine Wire plug. AGSF32FMF4 Be sure to check the gap as most plugs come with too wide of gap for the SHO. .044 is what you want.
tavius
arizona
Ok I will try that. I took the coils to autozone but they informed me that they had no way to check my coils and told me to take them to the dealer. does anyone know how much the dealer will charge for that?
They need to check them on the car and will charge big bucks. FWIW handling them tends to make them bad for what ever reason.
You can check them with an ohm meter and tell if it is completely dead. Between one of the input connectors and the output spring should be around 5k ohms or so. Open or shorted are both signs of it's demise.
tavius
arizona
ok I will try that first then. Thanks!
ArkanSHO
Arkansas
Sagabu said:
Bosch plugs SUCK ! :boink:
Correction, they suck in the SHO from most opinions. I have had them in almost every car I have owned including the wife's 360 powered RAM 2500 for over 100,000 and it purs like a cat. I also had them in the SHO for 300 miles and developed a miss, which after changing them out was still there. Finally reverted back from the cool sounding K&N cone under the hood to the Porterized air box and the miss went away. Guess it was a coincidence that the spring temperatures jumped into the 90's that week aggrivating the issue.
tavius
arizona
I ran a ohms check on the coils and they all were fine, i am going to order the AWSF-32FM plugs from www.carparts.com
ncfirefighter
north carolina
while we are on the subject of plugs is there away to remove the intake to change the plugs with out having to buy more gaskets?? and second question i know this might have been asked before so forgive me. is there away to check the coils with a meter mine has a slight miss at idle nothing major she is quick out of the hole and top end.
Mr Anonymous
Tire Wall
Yes, just remove the surge tank (as one piece, don't remove the runners from the tank).
There is a procedure for testing coils with a meter over on http://www.v8sho.com, but it's not terribly reliable since you can't exactly duplicate the conditions where misfiring might occur.
tavius
arizona
this is a good site for surge tank removal, although i did not need to remove the air box. http://www.geocities.com/motorcity/street/7499/sparkers.html
ArkanSHO
Arkansas
Just loosen the hose clamps. The rear support brackets are a PIA to get at even after you remove the passengerside winshield cowling.
