BEBOP
I have a 2010 ford sho with 97 thousand plus miles the car runs great at normal speeds but when pressing down on the gas peddle hard to go faster it start to misfire . the car would shake and the service engine light will blink while the car is shaking once the car quite shaking the service engine light would stop blinking and it would have a code that read p301 misfire i change the coil on cylinder 1 plus all the spark plug and i switch the coil from cylinder 1 to cylinder 6 to see would it change firing codes but it didnt it still reading misfire on (i clear the code)cylinder 1 (p301) and i also took it to the dealer and they ran a compression test that pass they also said that all of my fuel injectors were good ... can someone please help me with this problem....... i had seen on youtube pick up trucks that have the eco boost engine was having the same problem and what they did to fix it was made a weep hole in there inter cooler.... do anyone kows this really work ?
