Hiya,
The past week we've had some problems with the motor misfiring. We changed the oxygen sensors along with the ignition coil, because the codes said something about oxygen sensors and the ignition coil.
After replacement, the car ran ok for about a day, with me driving it to and from school, maybe about 5 miles total. The next day, as soon as I turn it on, it begins to misfire. I was pretty ****** off. I havent ran the codes since the second time it started misfiring, but when it does, it runs very rough, and idles just above 500rpm. Earlier today, my father and I took a look at one of the spark plugs because we thought it might be one of them that arent firing. It turned out to be pretty worn. So tonight, right after we bought some bosch platinum plugs, on the way home, the car would stall when you put the clutch in or let it get low. It just wouldnt idle on it's own! My father who was driving was able to keep the rpms up, even when stopped at a light. Could the car not idling right be part of the misfire problem? A while ago, we added some fuel injector cleaner to see if that helped, nothing noticable happened. If anybody has a tip or a question, just ask or even better, email me.
My car is a 1992 MTX with about 145k miles on it. No mods except for a catback system(that we know of) and a spoiler which wasnt original. It has a new ignition coil along with new spark plugs(not in yet). Also, if anybody knows a good mechaniac or who knows something about the SHO motor in northern VA, let me know. thanks
-andrew
<small>[ March 13, 2003, 08:11 PM: Message edited by: roadbratt ]</small>
-andrew
