SolidState
No Mo SHO
I am really chasing my tail on this one.
The car ran well when I got it, but I discovered oil in the plug wells and decided it was time for a 60k. I replaced everything except the plug wires, as they were really nice Magnacore wires. More on that later.
Once I was finished buttoning it up, it ran well. Until the fans kicked on. The idle raised, it ran fine. The rans kick off, and then the car seems to sputter, and the idle a little loopy. Although the tack doesn't really move.
Fast forward to about a month ago. I replaced the magnacore wires with some brand new Accel wires from SHOnut. The car ran well, idled better, was smoother, until the fans came on.
Last weekend, I tried to replace the CAM seals, but ran into a major issue with the crank bolt (another thread). I was unable to remove the harmonic balancer, but was successful in replacing the CAM seals.
This morning, the car seemed to start rough and run rough. So far, I've checked:
- the plugs, and they are white and properly gapped. Plug wells are dry.
- unplugged the MAF. The car nearly died, but recovered. Clean the MAF for good measure.
- replaced the air filter. Mostly for good measure.
Other notables:
- Restarts when warm are rough. Could be a weakening pump, but the car runs fine otherwise.
- Vacuum hoses are looking old. But none appear to leak. I pulled a couple, and the idle would rise, smooth out, then drop and stutter.
What puzzles me is that it runs okay, until the fans come on.
any ideas?
Other notables:
any ideas?
