Misc electrical related questions
Power Surge
Palm Coast, FL
I'll just list them out...
Keyless entry code. It's not on the trunk hinge. I know it's on the keyless module, but not sure where that is on this car. Any ideas?
ETC head unit. Can the Gen2 head unit with the solid buttons swap into a Gen1?
Radio. My car has a base model Ford stereo. I am pretty sure it was swapped into the car at some point. I believe the stock unit should have been the JBL Ford cassette player (like I had in my 91 plus). Do I need anything special to replace it? What years will swap in? Don't need anything crazy, even just a working original head unit would be fine.
Hmm. Think that's it for now.
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
keyless entry is mounted in the trunk its on drivers side behind the cardboard in the trunk. cant miss it its a black box with most times what looks to be a ant. wire in it
only1me
Missouri
Yepp the gen 2 eatc will swap right in.The jbl system was a bit more it had a wiring harness/cable running from the back of the stereo to the amp,and then the amp had its own wiring harness running to the speakers. Then there was the sub amp which was connected into the reg jbl amp, and ran the subs or sub. There is a bit more to it. I have a extra gen 2 ford premium/jbl radio,but without all the wiring it wont work.
