DerricksSHO
Last outing ran a 13.1 hope to see some better times got a few different tynes to try. Does the car have to relearn each time you load a new tune?
Yes it does. Look for the Inspection Readiness section in the owner's manual to give you an idea of the drive cycle needed for that to happen.
If you go through the drive cycle, you do not need to unplug the ground. If you want, you can do that as an additional step to ensure that a KAM reset happens, not a bad idea.
