melted cats`
SHOracer86
Florida
To start off i live in Massachusetts and the inspections up here are brutal.So one day my car was acting weird and came to find out it was clogged cats . So i broke out the stuff inside and found that alot of it was melted. What could cause this? I need to know cause im contemplating on whether buying an aftermarket y pipe wih high flow cats or jus goin to the junk yard and pickin one up to pass inspection.
operdot
USA
melted cats are a cause of fuel igniting inside them, you best bet to find the cause of the problem is finding out if you are running rich.
jedhead
westminster,ca
I would replace the thermostat and the temp sending unit for the EEC-IV. Those are most likely cause of your engine running rich.
Bob
SHOracer86
Florida
yea i replaced both of those sensors after i gutted out the cats and i have an a/f ratio gauge installed and it is always at stoich. My main concern was buying the y pipe with cats and the same thing happen to the new ones.
shoandtbird
gta canada
if you shop around you should find someone to install a custom y and magnaflow for 300-500 thats what i did and its all good now!
Wht91+
93 Green MTX
Oconomowoc,WI
Bob
Agreed :thumb:
