Master mechanics, HELP QUICK!!!!
RJ-92
Crappy NYS
Well, I got the motormount (Rear) disconected, and it is out of the subframe. But now I can't find room to snake it out from behind there. Where can I pull it out from behind the motor and how?
Thanx in advance
Shoman94
Maine
RJ-92:
Thanx in advance
You have to rotate it back and towards you. Lift the motor higher. Make sur you have the front motor mount unbolted from the subframe also.
Mike Kopstain
Arlington Heights, IL
You just got to do exactly what you said, snake it out. Just keep jacking the engine up until it starts lifting the car. (then stop :D ) You wil have to play with it and move it in all sorts of erotice positions before it comes out, but with enough foreplay it will give. :D
Glebtihonniaqw
