93SHO_2
The waterpump, O rings, T belt, A belt, CkPS are all in, the car runs great, not a single drip. It was dark last night when I finished, kids were all gathered around making their demands, laundry was in process, the phone rang 20 times while the better half was out shopping. It was not an un-interrupted process. Today after about 100 miles I found the oil slinger (that thin metal disk that is between the crank damper and the crank timing belt gear) on the floor of the garage.
Do I :
1.) trade it in
2.) be happy don't worry (there is no oil to
sling anyway since the crank seal is not
leaking)
3.) tear it apart again ?
If 3, can the lower timing cover be removed without removing the middle timing cover on a 3.2?
Do I :
1.) trade it in
leaking)
