Update on tensioner replacement: Sorry to report that the bad chain tensioner was not the only problem with the engine. After completeing the replacement of the tensioner and buttoning up the motor, it was start and for about 4 minutes everthing sounded great, but then the clattering returned this time the sound bounced from one area to another until it was continously all over the top end. Shortly after the oil pressure light came on. My only expaination is the motor is starved of oil either plug oil passages from depris or a bad oil pump. See the owner had been using Pennzoil at 5k oil change intervals (bad, bad, bad) the motor was ulta sludge. I've advised him to drop the pan and look for clues, if he's lucky it maybe just a block pick-up tube screen and he should also count on replacing the rod bearings. Worst case is oil pump replacement, which will be unfortunate since he has just recently had the front 60k service done. This is one wounded motor!
<small>[ December 22, 2002, 01:30 PM: Message edited by: gosho89 ]</small>
