Major Coolan Leak
Getlow_g
richmond,va
Major Coolant Leak
I just replaced my water pump, because I had a little leak, now I have a major leak coming from the front of the engine. It is not running down on the CPS but toward the front of the engine behind the down spout from the water pump where could it be coming from?
Rob94
Northbridge MA
HighSpeed said:
Where was it coming from?
Good response. It is helpful to other members if you post the solution to your original problem. Makes the search function helpful.
Getlow_g
richmond,va
I bought one at autozone and put it in and everything is working fine. It was the first time I ever replaced a water pump, which was bad, I didn't know the freeze plug had came out, but thanks to this site I had all the information and help that I needed to do the job, it wasn't hard at all plus I learned a lot about my SHO for the next time I need to break it down. Thanks guys. Peace
bmytych
