MAF confusion?!?!
93MTXSHO_STUD
lubbock, TX
Ok guys, just doing one thing to see what was acting up on my car. My car seems to run fine now, but when you unplug the MAF sensor the car seems to run a lot better! I've cleaned the contacts about 3 months ago, but I dont see why having it disconnected would give me better performance, I mean you can actually feel the sinking in your seat better with it unplugged! Is there a reason for this or do yall think I need to buy a new sensor?
PROPHET
Well-Known Member
Tonytown, Texas.
Have you tried resetting your computer to see if this helps, have you checked for codes?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Do you have a K&N?
Mine was bad, even with everything stock - Replacing it is the only way you'll fix it. They are not really that expensive.
Shoaz
Studly dood
Scottsdale, AZ
Did you just clean the contacts or did you clean the wire screen? If the screen is gunked up the car will run lean.
93MTXSHO_STUD
lubbock, TX
im running it with a K&N filter, i realize the oil from the filter is brutal on the contacts, no engine codes come on. So do yall think its time to replace the sensor? I know they run about 80 at autozone.
VTSHO
Guest
Keene
First go out and buy the cheaper papper filter. There like 10 bucks
If that fixes your problem then you know the oil from the K&N is what the problem is.
tinkerkathleen
