NealVA61
I need you guys assistance.
I just replaced my CPS for the second time since I've owned the car, '95 ATX.
Thought all was good with the world and then I noticed that the engine would idle so low when making a turn that it would basically die. I would see the oil pressure light flash and feel the steering stiffen up. However, when I accelerated again all would be back to normal. I have also had it idle so low that it would not stay running w/o my holding the brake and applying the accelerator at a traffic light.
This does not happen all the time. I suspect the IAC (or IAB whichever you know it as) but it seems coincidental that it started failing on me right after replacing the CPS. I know stranger things have happened and that the car is 16 yo now.
Does taking the IAC off and cleaning it make sense or should I just get a new one and replace it outright. This will be the third Ford that I've had with IAC problems.
Also, can anyone help me identify the gold colored thing next to what I believe is the fuel pressure regulator?
It appears to be leaking fuel and may be the primary source of the raw fuel under the hood, in the cockpit and around the car itself.
