loud tranny MTX
91_SHOster
Fresno,CA
Lately i've been noticing my Tranny is making alot of noise (especially when going into gear/downshifting and engine braking). My clutch is grabbing fine but it also seems like a TOB noise is there as well
Any thoughts?
SHO-NUF93
Zombie
Jacksonville, FL
I was wondering about this, too. Lately it seems like I have a lot of rattle idling in neutral, or really any time the clutch is released. I replaced the clutch in February, and made sure I topped off the fluid(but I did use some off-brand standard Dexron/Mercon ATF). The best way to describe it is a light rattling, but very noticeable. The car also makes a humming noise if I downshift while rolling(before letting the clutch out...it's like an ascending hum, I would believe it's synchros spinning up the selected gear before I release the clutch). It shifts smooth, and makes no serious knocking noises or anything. Just the rattle.
I read in a very old back issue of Road & Track(I think it was March, of '91) where they did a test of one of our cars, and the testers noted 'gear rattle at idle', it was stated in the article that it was the 'new' rod-shifted tranny. Any thoughts on this?
LeddZepp8687
The Keg Rider
Naperville, IL
I had a 95 MTX that I was driving and working on, He was a member of my local club. the car had a CM stage 1 clutch supposedly and one thing I noticed was that on any kind of cold tranny it made a brief sound that literally sounded like tranny internals flinging around. Sometimes it made a sound when taking off in first but rarely. I never could figure it out.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Check the fluid level for sure. Last time my tranny was making a noise, I found a hole in the case, and no fluid inside. It started out as a light rattle, and progressed to a loud rattle.
crystizel
