Loud squeeking rear windows
Eliw
Brooklyn NY
I need to relubricate the parts that are making a horrible squeeking sound when I put the rear windows down. I know there is a grease for that. Anybody know what it is? Also, instead of grease, would this (http://www.ballisticdrums.com/special-reports/penetro-90.htm) work?
Also, my front driver window is missing the guide that is inside the door all the way in the rear part of the door. It causes horrible wind noise since the window doesnt open or close correctly. I can get the window all the way down, but going up, it doesnt seem to go up all the way correctly. Anybody know how I can get the bar back on there? (I have the guide bar)
ohfosho
ontario SHOwner
ontario, canada
the guide bar that has one bolt and at the opposite end has a clip. that first has to pushed up and clips into the bottom of the upper window frame. then it blots down at the bottom...you'll know if it is clipped on at the top...it wont go anywhere but down if you have the bottom bolt out.
Eliw
Brooklyn NY
Thanks!! I took a look at the bar and I know exactly what you mean. Thanks big time.
poffffd
