Lotta Codes
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
So I checked my codes about 3 weeks ago and got the dreaded 214/211
211 (M) Ignition PIP signal was erratic or missing - Ignition Systems
214 (M) Error in Cylinder ID (CID) circuit or signal - Ignition Systems
Annnnnd i've been driving it like that, well, today, the car died and i feared the worst... but it started back up again, and as I was driving home, on the freeway (so about 60-70 MPH) it would studder a bit, and the tach was a bit jumpy (which ive heard is another symptom) the engine speed was not increasing from what i could tell... i was in 5th, so for it to increase 500-1200 rpm as fast as it did, i thought would be impossible)
I checked codes, now that I am home and got 2 more codes...
during the first series i got
114 (O,R) IAT sensor out of range - IAT
(the temp was about 24 degrees, which ive heard can happen below 50 degrees)
126 (O,R,M) MAP or BARO sensor out of range - ">MAP
Now, i was going to replace the CPS, will that fix my 211/214 code, or should i look elsewhere, it seems wierd that the cam sensor and crank sensor code would show up, but my physical symptoms seem to be pointing exclusively to the crank, but i suppose it is possible that both failed at the same time... since there is hesitation :shrug:
also is the BAP sensor another problem, or could it just be caused by the slew of other codes i got?...
thanks in advance
htheduck
NY
Bump for this thread, but not meant to hijack. I'm a noob when it comes to electroncis--but can someone explain the 214 code to me in laymen's terms: why, what, reason, etc.
Also, what are the negatives about driving for long periods of time/as well as distance with this CEL code?
It comes on within 5 minutes of a cold start. it's a 94 atx w/112k
Thanks.
