Brett
SHOs before HOs
So i sit down with this transmission and the SHONUT MTX rebuild dvd. Shit starts going wrong almost immediately. The second bolt to loosen, one that you only loosen and dont take out all the way because it holds a spring became stripped. The metal is so soft that vise grips just eat it. Tried grinding it down and using a big flat head, no avail. Ended up drilling it halfway and grabbing an edge with some pliers. FINALLY got that one out, replaced it with one from my broken case transmission. Id also like to mention that when i drilled this bolt, i did NOT go all the way through, close to half but at no point did the bit come out the other side. I'll get a pic of this bolt tonight. Also this bolt was VERY very tight. It looked so easy in the vid i checked my broken trans and that came out just as easily as the video.
Picture of drilled bolt. ****** quality but you can see that i didnt drill all the way through, just enough to get a surface to grab.
Even in these far off pics you can see where the gears are a shinier grey on the tips, but i dont think they could cause this much shavage
Get back on it last night, get the case off and find this.
The trans has also been worked on judging by all the RTV.
that is ALOT of metal shavings, but i cant find from where. A couple of the gears are missing a TINY amount of meterial from the tip of the teeth, nothing that should cause this much metal.
Whatever, keep going right? The video directs me to take a punch and pound out a pin. OFCOURSE that doesnt go the way its supposed to, now part of the punch is broken off in there and i have to get that out before i can get the pin out.
This is rediculous, nothing comes out easy and every little bolt is a DAYS long ordeal.
Where the F are those metal shavings coming from?
Heres the fun pin that has a broken punch in it. Would it be ok to drill out and use the pin from spare trans?
