So I tore everything back apart yesterday and snapped some photos.
So far all looks good.
High Res: http://www.abusivemotorsports.com/troy/SHO/Tranny/CIMG1537.JPG
Everything looked good with the revers pawl and shift gate.
High Res: http://www.abusivemotorsports.com/troy/SHO/Tranny/CIMG1541.JPG
Can't really tell, but I think this here whizbang is causing my grief.
High Res:http://www.abusivemotorsports.com/troy/SHO/Tranny/CIMG1540.JPG
Once it was out of the tranny, the synchro clippy things fell out. I guess it's good I couldn't engage reverse because I think these would have flown off into the gear cluster and caused me some real problems.
High Res:
http://www.abusivemotorsports.com/troy/SHO/Tranny/CIMG1545.JPG
I thought this was a 5th gear thingus but apparently 5th and reverse are somewhat linked up. and according to http://www.shoforum.com/showthread.php?t=82789 they share a syncro. Welp, 5th gear was kinda "ganky" and I think this explains it.
High Res:http://www.abusivemotorsports.com/troy/SHO/Tranny/CIMG1550.JPG
I'm pretty sure this is what it is supposed to look like. Hopefully I get some positive validation for my gut feelings 'cause I'd like to get the tranny back together tonight and the car back together on Friday.
Symptoms were: Reverse would not engage, shifter would not go into reverse slot, linkage checked out fine, 5th gear had slight grind.
High Res:
Normally I think of a pinion shaft when I think of "whiz-bangs", but it's all good.
